Model D Reissue mod wheel Vibrato
I am new Moog Model D owner. I have been trying to get a decent Vibrato with the Mod Wheel using the LFO and also tried using the 3rd Osc as an LFO. Im just not getting it. Does anyone have any suggestions. Would love some input. Thanks!!!!
Re: Model D Reissue mod whell Vibrato
The amount of modulation from the Mod Wheel to the VCOs is quite a lot, thus making it quite difficult to control the vibrato.
1. The Oscillator Modulation switch should be set to ON
2. The LFO shape should be triangle
3. Set the frequency of the LFO to something like 3
4. The switch under the knob in the Modulation Mix should be set to LFO and finally
5. The knob Modulation mix should be set to 10 (fully clockwise) - just to get vibrato solely from the internal LFO.
Just push the Mod Wheel a little and you will get vibrato. Adjust the LFO frequency and the Mod Wheel to taste.
Hope this helps.
Hope this helps.
The walls of Jericho were brought down by a Minimoog.
i got the same issue with the strenght of the modulation weehl and i have installed the muse interface which has the ability to reduce the modulation amount . it´s great now to play with less modulation control .
Does it reduce the modulation amount for both oscillators and filters, or just the oscillators?Minimooger wrote:i got the same issue with the strenght of the modulation weehl and i have installed the muse interface which has the ability to reduce the modulation amount . it´s great now to play with less modulation control .
i just checked - it reduces the amount of all destinations - filters as well as oscillators .
in the first attempt the new "modulation matrix" of the reissue was little confusing for me but as soon as i learned to handle it in conjucntion with the muse interface i am quite confident with this instrument .
