I used to use Ableton with my 2016 reissue model D via CV tools. That was the only way I could record and replay after- touch. Midi only records note and velocity, not after-touch.
I am using Logic pro X now for film scoring. I do not see CV control in Logic Pro X.
Does any one know anything similar to Ableton CV tools for Logic pro X?
Thank you.
CV tools for Logic Pro X ?
Re: CV tools for Logic Pro X ?
I figured this out. Native Instrument Reactor has Note In and Pitch CV Out tools. Both in combination, I can trigger CV. Thank you.
Hey there! Logic doesn't have built-in CV tools like Ableton, but there are ways to capture aftertouch in Logic Pro X:
Some newer reissues of the Model D have built-in USB MIDI, which allows aftertouch data to be recorded directly. Check your specific model's specs. Explore plugins like "M4L" or "CVilization" (not Logic-specific) voojio that might offer similar functionality to Ableton's CV tools.
Hope this helps!
Hope this helps!
