Minitaur Audio In
Scriptura
Minitaur Audio In
Post by Scriptura » Sat Mar 23, 2024 7:53 am
Hello,
I want feed the audio in from the Minitaur with my electric bass.
Is there a preset available, which I can switch to the audio in signal?
I don’t understand the manual “You can use the Minitaur to process any audio signal simply by plugging into the AUDIO IN jack. To hear the external audio signal, you will need a MIDI NOTE ON message.” Cause every note from my midi keyboard is a midi note message, or not?
Thanks in advice :)
till
Re: Minitaur Audio In
Post by till » Mon Mar 25, 2024 7:21 am
You need to play a not to hear something from the Minitaur.
Sequence:
Scriptura
Post by Scriptura » Mon Mar 25, 2024 3:24 pm
Okay, I plug in my bass in a preamp, then from the preamp out, I go to the audio in from the Minotaur and nothing comes out…
Please explain, what must I do?
With the midi keyboard everything works fine.
Acid Mitch
Post by Acid Mitch » Wed Apr 03, 2024 8:56 am
Scriptura wrote: Mon Mar 25, 2024 3:24 pm Okay, I plug in my bass in a preamp, then from the preamp out, I go to the audio in from the Minotaur and nothing comes out…
While doing that you need to hold down a note to open the gate. Any note will do.
Also make sure "ext input" is turned up. Try it at 100% to start with.
hieronymous
Post by hieronymous » Sat Apr 06, 2024 12:19 am
Is this a good time for this pic?
Acid Mitch
Post by Acid Mitch » Sat Apr 06, 2024 1:49 pm
^ Probably safer than bricks and less messy than tape, :lol:
Also try starting with the envelopes set to 0 attack, 0 decay and full sustain.
Herr Mosa
Post by Herr Mosa » Sun Apr 07, 2024 3:29 am
From the Minitaur v2.2 manual - this should open the gate for external audio, too?
DRONE ON/OFF:
GLIDE + AMP SUSTAIN (Min to Max = ON)
GLIDE + AMP SUSTAIN (Max to Min = OFF)
https://api.moogmusic.com/sites/defaul ... dendum.pdf
mod d 2017 muse, sub37, minitaur, mf101, mf102, mf103
